The functionality of the code consists of requesting the position from each motor and sending an array through the serial port containing motor1 position, time, and motor2 position. This way, I can plot the data on my computer.
The problem is that sometimes, for some reason, the order is correct, but other times, the array I receive is motor2 position, time, motor1 position. This inconsistency makes it impossible to read the positions accurately, as the graph ends up with strange spikes.
Here is the current code:
void printMotorPositions() {
float position1Motor0 = readPosition(0);
float position2Motor1 = readPosition(1);
unsigned long currentMillis = millis();
Serial.print("[");
Serial.print(position1Motor0);
Serial.print(",");
Serial.print(currentMillis);
Serial.print(",");
Serial.print(position2Motor1);
Serial.println("]");
float readPosition(int axis) {
String command = String("r axis") + axis + String(".encoder.pos_estimate\n");
odrive_serial.print(command);
String response = readResponse();
// Parse response to ensure it matches the expected format
// This can be enhanced with more sophisticated checks
return response.toFloat();
String readResponse() {
String response = "";
unsigned long startMillis = millis();
const unsigned long timeout = 1000;
while (millis() - startMillis < timeout) {
if (odrive_serial.available()) {
char c = odrive_serial.read();
if (c == '\n') {
break;
response += c;
return response;
