I am currently operating the oDrive (v3.6 hardware / 24V power + firmware v0.5.2) at 100% load indefinitely, my application is similar to (ebike, direct drive robot arm etc). Below are couple details about my setup:
- i am using a very small 5V fan, positioned over the ODrive MOSFETs heatsinks
- current_lim set = 85A
- I am not monitoring the motor temp, or the oDrive onboard thermistors temp (big mistake)
- I am driving Flipsky 6374 190 KV motor
- requested_current_range = 100 A
Recently my oDrive failed while driving at 100% load, when trying to salvage the oDrive on the bench and running calibration mode the oDrive this happens:
as soon as I sent the command odrv0.axis0.requested_state = AXIS_STATE_MOTOR_CALIBRATION , I heard kind of a spark, and when dump errors i see CURRENT_LIMIT_VIOLATION.
- My current hypothesis is that some of the MOSFETs have failed due to overheating. Does anyone have another hypothesis of what might be going wrong?
- It seems that mosfets usually go short, can I use my finger to measure of any is overheating after setting the following mode AXIS_STATE_MOTOR_CALIBRATION? Can the mosfet act like an open circuit instead (how can i debug it if it is open)?
Thank you Community
