i am using 3 odrives v3.6 56v. I set the configuration on one odrive so that it works with the motors that I am using. I took a backup of the configuration and I restored that backup to the other drivers. when I did that I got this “error”:
odrivetool restore-config my_config.json
Waiting for ODrive…
Restoring configuration from my_config.json…
Could not restore axis0.controller.config.anticogging.calib_anticogging: ‘anonymous_interface_140344465817672’ object has no attribute ‘exchange’
Could not restore axis0.controller.config.anticogging.cogging_ratio: ‘anonymous_interface_140344465814312’ object has no attribute ‘exchange’
Could not restore axis0.controller.config.anticogging.index: ‘anonymous_interface_140344465821544’ object has no attribute ‘exchange’
Could not restore axis1.controller.config.anticogging.calib_anticogging: ‘anonymous_interface_140344465817672’ object has no attribute ‘exchange’
Could not restore axis1.controller.config.anticogging.cogging_ratio: ‘anonymous_interface_140344465814312’ object has no attribute ‘exchange’
Could not restore axis1.controller.config.anticogging.index: ‘anonymous_interface_140344465821544’ object has no attribute ‘exchange’
Could not restore can.config.baud_rate: ‘anonymous_interface_140344465821544’ object has no attribute ‘exchange’
Some of the configuration could not be restored.
Configuration restored.
When I try to calibrate and move the motor with the odrive that I restored the configuration on, it doesn’t move the motor at all and I get this error: In [2]: dump_errors(odrv0)
system: not found
axis: Error(s):
UNKNOWN ERROR: 0x00000040
motor: Error(s):
MOTOR_ERROR_PHASE_RESISTANCE_OUT_OF_RANGE
axis1
axis: Error(s):
UNKNOWN ERROR: 0x00000008
motor: no error
what can I do to solve this?
kind regards
CM
