Motor jerking reverse and forward in velocity and position mode?
i AM USING Odrv3.6 purchased from China, firmware version is 0.5.1.
My motor is RI50 dc motor. Encoder cpr is 560 Incremental mode.
The problem is MOTOR is vibrating BACK and FORTH, means moving in REVERSE and FORWARD directions both in POSITION and VELOCITY mode.
The calibration is okay without any errors, and motor running smoothly in SENSORLESS_MODE also. here is my controller configurations settings, please check and suggest me solutions please. thanks.
In [39]: odrv0.axis0.controller
Out[39]:
anticogging_valid: False (bool)
config:
anticogging: {…}
axis_to_mirror: 255 (uint8)
control_mode: 3 (int32)
enable_current_mode_vel_limit: True (bool)
enable_gain_scheduling: True (bool)
enable_vel_limit: True (bool)
homing_speed: 40.0 (float)
inertia: 0.0 (float)
input_filter_bandwidth: 50.0 (float)
input_mode: 2 (int32)
load_encoder_axis: 0 (uint8)
mirror_ratio: 1.0 (float)
pos_gain: 0.5 (float)
torque_ramp_rate: 0.05000000074505806 (float)
vel_gain: 0.0005000000237487257 (float)
vel_integrator_gain: 0.0024999999441206455 (float)
vel_limit: 1000.0 (float)
vel_limit_tolerance: 100.0 (float)
vel_ramp_rate: 0.5 (float)
error: 0 (int32)
input_pos: 0.008888889104127884 (float)
input_torque: 0.0 (float)
input_vel: 0.0 (float)
move_incremental(displacement: float, from_input_pos: bool)
pos_setpoint: -5.505317687988281 (float)
torque_setpoint: 0.0 (float)
trajectory_done: True (bool)
vel_integrator_torque: -0.0005316188326105475 (float)
vel_setpoint: 0.0 (float)
Hi!
Unfortunately we can’t support third-party ODrive clones. They’re typically based off of much earlier ODrive versions (v3.4 or v3.5), and have significant reliability and signal integrity issues. If it was sold to you as a genuine ODrive product, you should ask for your money back. I’d recommend picking up an ODrive S1, as it has greater performance, reliability, and support for our new web GUI.
