Motor parameter not updated in Web GUI
I am facing a problem using the Web GUI for a ODrive Micro with firmware 0.6.12.
If i open the Web GUI for a an ODrive already configurated a few days before, the edit fields in the configuration menu did not show the actual stored values. The default settings are shown in the different submenus (e.g. DC bus overvoltage trip level is empty). I checked the actual values with the odrivetool. There the actual settings from the last saved configuration are shown correctly.
Hi! The Web GUI only stores the loaded configuration from the browser locally (e.g. stored in the cache). Sometimes you need to enable the site’s permissions to store data, or that won’t work. That being said, if you’re looking to just do some small edits, I’d recommend doing so in the inspector tab, where you have full parameter access (same as in ODrivetool).
