I’m trying to read temperature with integrated thermistor inside my hub motor.
After connecting the thermistor with voltage divider pcb and setting up thermistor gpio pin to 3 and thermistor coefficients, the temperature still reads NAN (with no errors).
Reading the analog pin 3 with odrv0.get_adc_voltage(3) gives me 0.19V. The value is changing as I spin the motor. The motor can’t be controlled when motor thermistor is enabled (because of the NAN value?)
@rowanG thanks for the update. I’m just diving into this and wanted to see if we could implement this on the odrive or if it should be done on another micro controller . I believe @killko had the original issue.
