Hi guys, I just complied the latest firmware with configuration for v3.1 board, using native USB and step/dir GPIO config. I hooked up motor1
After flashing I can hear the beep and the motor does a slow test rotation
https://youtu.be/e_R5W8HbhVE
now I’m trying to run demo.py (after modifying to run motor1 instead of motor0), the system can access odrive through USB and I’m getting the proper VBUS readout (~17.6V), it’s going through the sine wave test but the motor is not spinning, any ideas why or how to debug this?
here’s demo1.py
#!/usr/bin/env python3
Example usage of the ODrive python library to monitor and control ODrive devices
from __future__ import print_function
import odrive.core
import time
import math
# Find a connected ODrive (this will block until you connect one)
my_drive = odrive.core.find_any(consider_usb=True, consider_serial=False, printer=print)
# The above call returns a python object with a dynamically generated type. The
# type hierarchy will correspond to the endpoint list in `MotorControl/protocol.cpp`.
# You can also inspect the object using the dir-function:
#print(dir(my_drive))
#print(dir(my_drive.motor1))
# TODO: maybe provide an introspection method that dumps the whole type hierarchy at once
# To read a value, simply read the property
print("Bus voltage is " + str(my_drive.vbus_voltage) + "V")
# Or to change a value, just assign to the property
my_drive.motor1.pos_setpoint = 3.14
print("Position setpoint is " + str(my_drive.motor1.pos_setpoint))
# And this is how function calls are done:
my_drive.motor1.set_pos_setpoint(0.0, 0.0, 0.0)
# A little sine wave to test
t0 = time.monotonic()
while True:
setpoint = 10000.0 * math.sin((time.monotonic() - t0)*2)
print("goto " + str(int(setpoint)))
my_drive.motor1.set_pos_setpoint(setpoint, 0.0, 0.0)
time.sleep(0.01)
# Some more things you can try:
# Write to a read-only property:
my_drive.vbus_voltage = 11.0 # fails with `AttributeError: can't set attribute`
# Assign an incompatible value:
my_drive.motor1.pos_setpoint = "I like trains" # fails with `ValueError: could not convert string to float`
