I run odrive under postion control mode, and set input_pos = 0.0
it locked well.
I can feel that the motor is producing force when I use external force to rotate the motor.
But the current rises to about 0.7A, and the current does not rise no matter how much the position error increases.
odrv0.axis0.motor.config.torque_lim is already inf
what’s wroing?
                towen
              2
              do you also have a motor.config.current_lim ?
You can try increasing that (but not to Inf)
              thank thee very much!
i set motor.config.current_lim 12, change it larger, then it worked as expect.
so the unit of current_lim is not Amp?
              current_lim is in Amps, yes.  But the current you see at the power supply != the current in the motor.
