It looks like I am sending and I can see something spitting back fro Odrive on my scope, but I think something is amiss with my software.
My board is a custom version of a Teensy 3.2. I am using the TeensyArduino software running on PlatformIO. Essentially, I am trying to verify that I can send commands and get data back, but the data is always zeros.
My code:
#include <Arduino.h>
#include <SoftwareSerial.h>
#include <ODriveArduino.h>
// Printing with stream operator
template inline Print& operator <<(Print &obj, T arg) { obj.print(arg); return obj; }
template<> inline Print& operator <<(Print &obj, float arg) { obj.print(arg, 4); return obj; }
// Serial to the ODrive
SoftwareSerial odrive_serial(0, 1); //RX (ODrive TX), TX (ODrive RX)
// ODrive object
ODriveArduino odrive(odrive_serial);
void setup()
// TCXO Oscillator Setup
// Clear EREFS2 bit in MCG_C2 - External reference clock requested.
MCG_C2 = 0x20; // MLD 6/13/20
// Below are some sample configurations.
// You can comment out the default Teensy one and uncomment the one you wish to use.
// You can of course use something different if you like
// Don't forget to also connect ODrive GND to Arduino GND.
// Teensy 3 and 4 (all versions) - Serial1
// pin 0: RX - connect to ODrive TX
// pin 1: TX - connect to ODrive RX
// See https://www.pjrc.com/teensy/td_uart.html for other options on Teensy
// ODrive uses 115200 baud
odrive_serial.begin(115200);
// Serial to PC for debugging
Serial.begin(115200);
analogReadResolution(12); // Set all A/D converters to 12-bit precision.
} // END setup()
void loop()
analog_inputs ();
digital_grip_io ();
if (PrintDelay++ > 100) // Do this every 500mS.
Serial.print("Analog Channel X = ");
Serial.println(average_x);
Serial.print("Analog Channel Y = ");
Serial.println(average_y);
Serial << "Vbus voltage: " << odrive.getBusVoltage() << '\n';
Serial << "Roll_Pos: " << odrive.GetParameter(0, odrive.PARAM_FLOAT_ENCODER_PLL_POS) << '\n';
Serial << "Pitch_Pos: " << odrive.GetParameter(1, odrive.PARAM_FLOAT_ENCODER_PLL_POS) << '\n';
Serial << '\n';
PrintDelay = 0;
// A brief delay, so this loop runs "approximately" once every 5 milliseconds.
delay(5);
} // END loop ()
