Hi, all you very smart people, please share your wisdom.
Package arrived today.
What do I do with the two tiny wires on D6374 - 150KV?
Secondly:
The encoder? has anyone ever successfully connected a CUI AMT102 to the rear of the D6374; I mean does it just float around in space?? (cant screw it down).
While it may go in the front (although the bases holes are misaligned); the sleeve and the shaft adapter donāt fit 12mm.
I donāt have that motor but I believe it does have a thermistor which would match your description of wire diameter. You absolutely need to affix the encoder securely or the controller is going to get confused about the minute movements that are āhappeningā. As for mounting the encoder, people have been using aluminum angle plate, 3d printing adapters, etc. AMT has files of all sorts of formats to extract measurements and the likes from on their website.
The Motor was purchased from your web site and in the image you can see 2 minute wires; my worry was āno where does it say what to do with themā and I thought it may cause issues if they you just left them unconnected. (maybe Oskar knows)
āmounting the encoderā yes I noticed the encoder housed, is very sloppy on the shaft as the shaft adapter āfittedā only allowed 0.05 mm gap (feeler gauge) between housing and motor; this tolerance I believe is too small, as errors or worse could occur.
To alleviate this fine tolerance I will hand make (A jeweller in past life) a 0.05 mm shim to add thickness to the shaft, allowing the shaft adapter to sit back off the motor.
I would be better if the encoder would mount to the front, but only 8mm fitting and not 10mm.
You have suggested the AMT site for information, so I will have a look and see what they can offer.
Just to be clear, Iām not affiliated with ODrive; just an enthusiast with too much time on his hands.
Youāll be fine if you donāt hook up those two wires. The vast majority of folks donāt have motors with thermistors embedded at all. It may be that certain GPIO pins are intended for the thermistor and maybe some logging of temps or similar that Iām not aware of.
Not sure I follow on the fitment/clearance issue, you may have to post a picture. The bore of the encoder should slop around a bit relative to the body, but with CUIās adapters you should get a snug fit around the shaft itself. From there itās just a matter of holding the encoder body rigidly to prevent any movement within that āsloppyā region.
You answer a lot of questions, so I thought you might be a part of the team. anyway I sure they would welcome you as a team member!
Good so no worries about the wires.
āThe bore of the encoder should slop around a bit relative to the bodyā
So this is normal! I just had the wrong impression about the tolerance, and yes when I fit the encoder to the housing I will make it a snug, centred fit.
Firstly with these wires; I suppose its possible to obtain feedback by connection to the ODrive board, Yes/No?
Mounting: It is not so much the mounting (just a mount -Alloy or 3D print) has to be made.
1/ The issue for me is that, the shaft āsleeveā and the āshaft adapterā when fitted put the encoder tooooo close to the motor as it spins!
In prior post (0.05 mm shim) I will make the aforementioned to alleviate this issue, which in turn will give 1mm space between spinning Motor and Encoder.
2/ Movement of encoder (sloppy) when fitted to the shaft, seemed to me to much play! but that appears to be normal; and of course when the encoder is screwed down to the housing it is up to me to make sure it is not ill-fitted, and will operate as it should.
3/ Ideally, the encoder would be better if fitted to the front of the motor, but I guess this is not possible as the AMT10 only has fittings for a 8mm shaft; Or does it? maybe someone has made an adapter
Lastly: Iām away for the weekend so no motor close enough to snap an image, will post early in the new week.
I donāt actually know if the thermistor code has been setup yet. @madcowswe?
Please ensure youāve used the wrench for spacing as indicated in the AMT102 instructions. It should be about 1.5mm
It should come with multiple inner plastic rings. The blue one is 8mm but the others range. You should be able to mount the encoder on either end of the motor.
HI Wetmelon, thank you for your input, I appreciate your comments and help.
1/ (thermistor code) from what Iāve read so far, seems to be in the wind, so not now.
2/ (encoder to shaft) problem solved @ 1.4mm
3/ (AMT10 shaft fittings) the blue is the largest at 8mm
