Recently we order 20 oddrives of 56 volts, what are the paramters that we need to configer with 24 volts? Cant activate brushless dc motor in 150 RPM.
When we used the 24 volts its work propethly
There are no differences in the configuration - it should work.
Maybe the boards run different firmware versions?
What problem do you get exactly? Can you post the output of dump_errors(odrv0) ?
