I made this case in order to hold the Odrive to T slot aluminum rails. The break resistor is inside the case and for now there is no mounting holes for fans, but I’m testing that with heat increase inside the case. And I might add it in the future.
If you’re in search for Odrive case consider this and give me your feedback.
The plan was to test the case with Odrive to see how it will handle the heat. So far, I have been using it with one motor and I had no issues. but I’ll add some fans as upgrade in V2 in the future, when I connect the second motor.
