Is there a pinout for the Odrive 3.6 or 3.5 board that lists the specs for the pins?
Specifically I am wondering what the current output of the onboard voltage regulator that is connected is connected to the 5V pin?
I’d like to drive a couple of 30mm 5V DC cooling fans off this pin. the fans are 0.4W
Thank you
or can someone give me the part number for the onboard voltage regulator?
I think it should be safe to draw up to 500mA on the 5V rail.
so I ended up getting a couple of these 30mm fans that are 0.12 A, 5V.
I’m going to design a 3D printable enclosure that incorporates these as well as some tabs for bolting the case down. I’ll prob upload to thingiverse and include a link.
