I’ve been bench testing for a few months now on with a 56V odrive 3.6. Powered up the PSU today and suddenly have no communication with the board. The power led lights up. But serial commands won’t work. Usb communication doesn’t work. I have no idea what might have happened as I made no changes since I last used it two days ago.
I’ve tried changing usb ports and cables. I’ve tried a different OS. In windows, the device doesn’t show up at all in the device manager. If I switch to DFU it does show up. So I figured I’d try to re flash the firmware
I’ve tried using odrivetool dfu on both windows and mac. With the dip switch on run it just hangs at Wating for Odrive…
When I switch to DFU I get this (on osx):
ODrive control utility v0.4.11
Waiting for ODrive…
File “/usr/local/bin/odrivetool”, line 142, in
File “/usr/local/lib/python3.7/site-packages/odrive/dfu.py”, line 454, in launch_dfu
File “/usr/local/lib/python3.7/site-packages/odrive/dfu.py”, line 266, in update_device
otp_data = dfudev.read_sector(otp_sector)
File “/usr/local/lib/python3.7/site-packages/odrive/dfuse/DfuDevice.py”, line 195, in read_sector
self.set_address_safe(sector[‘addr’])
File “/usr/local/lib/python3.7/site-packages/odrive/dfuse/DfuDevice.py”, line 159, in set_address_safe
raise RuntimeError(“An error occured. Device Status: {!r}”.format(status))
RuntimeError: An error occured. Device Status: (11, 10, 0, 0)
Segmentation fault: 11
I get a different error in windows.
I’ve tried to use the STLink to flash. It failed as well.
sudo openocd -f interface/stlink-v2.cfg -f target/stm32f4x.cfg -c init -c “reset halt” -c “flash write_image erase ODriveFirmware_v3.6-56V.elf” -c “reset run” -c exit
Open On-Chip Debugger 0.10.0
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : auto-selecting first available session transport “hla_swd”. To override use 'transport select '.
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
adapter speed: 2000 kHz
adapter_nsrst_delay: 100
none separate
Info : Unable to match requested speed 2000 kHz, using 1800 kHz
Info : clock speed 1800 kHz
Info : STLINK v2 JTAG v29 API v2 SWIM v7 VID 0x0483 PID 0x3748
Info : using stlink api v2
Info : Target voltage: 3.153975
Info : stm32f4x.cpu: hardware has 6 breakpoints, 4 watchpoints
adapter speed: 1800 kHz
target halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0xfffffffe msp: 0xfffffffc
auto erase enabled
Info : device id = 0x10076413
Warn : STM32 flash size failed, probe inaccurate - assuming 1024k flash
Info : flash size = 1024kbytes
Error: stm32x device protected
Error: failed erasing sectors 0 to 5
Any thoughts on what else to try? Any idea as to what might have occurred? I need to buy 3 more odrives to complete my project, but now I’m a bit concerned about the reliability.
Thanks for any help in advance!
