Hello all
Does anyone know the inrush current of a odrive when it turned on.
I want to turn it on and off with a relay. The reason is that I will use a arduino as a safety controller
on my robot. If a unsafely situation happens I want the arduino to turnoff odrive.
I try a 10A relay but it got stuck. Will try a 30A relay. Or is there another way to prevent the current.
My robot will only use 5A
I’m not sure where all the current is going. If I connect the odrive the caps should get full. But if I disconnect it for half a second and connect it again I get allot of current flowing.
Cannot measure current at this moment blew up the fuse in my meter.
