I was working on automating the backup and restore configs for a series of odrive boards based on serial number. I was referencing the source for odrivetool to see how backup_config and restore_config were being done and figuring out what I could leverage from there. After I wrote my script and tried executing it with my version of odrive installed through pip so I could ensure it would work on other computers, and I started getting “ModuleNotFoundError: No module named ‘odrive.configuration’”.
This prompted me to look into my local odrive installation in C:\Program Files\Python311. It looks like the version of odrivetool that gets put in C:\Program Files\Python311\Scripts and the version of odrive that is put in C:\Program Files\Python311\Lib\site-packages\odrive are different than anything I can find searching through the git repo. The version that is downloaded with pip is referencing legacy_config.py instead of configuration.py to do the backup and restore through odrivetool (among other differences in the actual source of odrivetool.py).
Another interesting piece of this is that if I do odrivetool --version it returns “ODrive control utility v0.6.8” which doesn’t seem correct.
Is there a reason these two versions of Odrive are so much out of sync, and is there a way to see what version is actually getting sourced through pip?
