Running motor calibration causes ODrive to stop working. The USB drive does not work and only works when the board is rebooted. Any guesses as to the cause?
I am using ODrive V3.5 version. My guess is that the Mosfet is not responding.
Electrical noise on USB. Make sure you’re using the ferrite rings on the motor phases and a USB isolator.
I uploaded a new firmware and tested it, but the symptoms are the same. For other boards it works fine. When I checked the MOSFET with a tester, I found that one MOSFET line was strange. Could this be a problem?
Yes it’s possible
