I have encountered some problems when using the odriveGUI. When I use the odrivetool to connect to the odrive, there are no problems and debugging can be carried out, but I can’t connect when I exit the odrivetool and connect to the odriveGUI alone. There should be no problem with the USB cable, because I can use the odrivetool normally.
Is the program incremental PID or absolute PID?Can anyone resolve my confusion?
OK a couple things:
- You can only connect to the GUI or odrivetool, not both at the same time.
- Sometimes the GUI or odrivetool refuses to close a python process in the background. CTRL+ALT+DEL → Kill Python.exe
- I’m not sure it works in anaconda?
I’m not familiar with these terms, can you expand?
