Hi All
I was having trouble getting the odrive to work with MPU6050 and I seem to have found the solution although I need a clarification. Bear with me and let me walkthrough what I discovered. I am using jrowberg mpu library which can be found here.
I modified the code a bit so that I can use it as a class which can be found here.(gyro.cpp)
Initially I had the calibration routine as so and put it in setup():
Serial1 << "r axis" << L1_MOTOR << ".encoder.is_ready\n";
bool L_done=odrive.readInt();
Serial1 << "r axis" << R0_MOTOR << ".encoder.is_ready\n";
bool R_done=odrive.readInt();
requested_state = ODriveArduino::AXIS_STATE_ENCODER_OFFSET_CALIBRATION;
while(L_done==0){
odrive.run_state(L1_MOTOR, requested_state, true);
delay(50);
delay(50);
while(R_done==0){
odrive.run_state(R0_MOTOR, requested_state, true);
delay(50);
delay(50);
I put this code before I initialise the mpu since putting this code block after the mpu initialisation cause the arduino to freeze after some time once it enters the closed-loop state. I initialised the closed-loop state through serial in loop(). Even so, arduino still freezes after some time. Instead I tried by initialising the closed loop state immediately after calibration like so:
while(L_done==0){
delay(50);
delay(50);
requested_state = ODriveArduino::AXIS_STATE_CLOSED_LOOP_CONTROL;
odrive.run_state(L1_MOTOR, requested_state, false);
while(R_done==0){
delay(50);
delay(50);
odrive.run_state(R0_MOTOR, requested_state, false);
This time it works. Arduino doesn’t freeze anymore! I couldn’t find out why this is the case. I tried looking into the odrive firmware folder but to no avail.
Anyone here knows why entering closed-loop state immediately after calibration doesn’t cause arduino to freeze?
