Working on Windows, after using the STM32CubeProgrammer to flash firmware to an ODrive V3.6-56V with the dip switch set to DFU, the ODrive seems to have no current flowing through based on the reading on the power source. This is after switching the dip switch back to RUN mode, which doesn’t make sense because prior to flashing firmware, the ODrive was working perfectly fine and there was a current > 0 on the power supply when in RUN mode.
Anyone have similar issues with connecting after flashing firmware?
