Hi! Are there any instruction about how to properly assembly ODrive Pro with heat spreader plate and heatsink and fun? For me it’s not clear what should I put between ODrive Pro MOSFETS and heat plate (green thermal pad?), also should I use some thermal paste between heat plate and heatsink? Thanks. Video on YouTube will be very useful.
A video is a great idea here, thanks for the suggestion!
Yes, the green thermal pad goes between the MOSFETS and the heat spreader plate, there should also be a brown thermal pad that goes between the heat spreader plate and the heatsink/fan. Thermal grease is a great (better) substitute for this brown thermal pad, but it should not be used on the MOSFETS.
Hi! Thanks for the answers and welcome to the ODrive team (I guess)
What about an avatar picture to easily detect odrive’s crew member messages in threads? =)
