Hello! I’ve been using ODrive pros for a project that I am working on successfully for a few weeks but as I started working on it today it seems something has gone wrong with my ODrive. It can fully connect with odrive tool in powershell on my windows laptop but will not connect to the web gui.
Things I’ve tried:
Power cycling
Trying different cable and different usb isolator
DFU for the ODrive pro
Plugging in another ODrive pro (No problems with a different one)
None of these solutions worked and i’m a bit lost on what to try to do going forwards. It doesn’t seem to be a firmware issue on the ODrive or an issue with drivers.
Let me know if you need any more information or have any ideas with things to try. Thanks!
Thanks for the reply, thankfully I did figure it out though. Apparently even though the wiki says that you can either use Win USB or libusb-win32 drivers from Zadig, It looks like the Web GUI is only able to find the ODrives if you are using the Win USB drivers, at least on my computer.
Not sure exactly what is causing this, I’m using chrome as my browser and like I said before I am able to find and connect to the ODrive with odrivetool in powershell. If anyone at ODrive needs more info about my computer/setup to try and fix this I’d be happy to post more info, just let me know
