Is the ODrive able to run an escooter motor at its rated speed?
For example I’m planning on swapping the motor controller from my existing scooter to an ODrive and want to be sure I’ll be able to match the current performance.
I recall the docs somewhere mentioning it can only do up to 75% or rated speed. Is this still the case?
So essentially, the Odrive is only capable of running a motor to 75% of its rated speed (at rated bus voltage)? Am I correct in saying this has something to do with how the ODrive is doing it’s current monitoring for the FOC loop?
Based on this, would the only way to run a motor at it’s rated speed be to have a bus voltage of 1/0.75=1.333 times the motors rated voltage?
Yes. With ODrive v3.x due to having only 2 current sensors, it needs some dead time to be able to sample the current sensors away from the PWM switching edges.
You can use a motor rated for 36V or 24V and run it at 48V happily though.
The voltage ratings on hobby motors are designed to protect them from mechanical overspeed, not overvoltage.
Even ‘bog standard’ enamel wire insulation is good for a few hundreds of volts. You can’t really over voltage a motor at 60V.
Yes, ODrive V4 (to be released "Soon"tm) will have 3 shunts, so it will always be able to pick two phases which are not going to see a PWM edge within the ADC sampling window, so I understand.
