good day I am the owner of a motion platform with 3x odrive plugged into one usb hub3.0 connected to an extended usb 2.0 active . my question is . try to plug 3x usb ground isolator into the hub. the problem is that I do not want to work if I plug them all three into the usb hub .if I plug one works if I plug the others stop working either all or one of them( does not detect me then the ports for odrive in the computer) any idea why? maybe i need to change the usb 2.0 extension to usb 3.0? thank you for your help. Hausdec Adum3160 Digital Signal… https://www.amazon.co.uk/dp/B0C9LCT51G?ref=ppx_pop_mob_ap_share
What hub exactly are you using? The isolators definitely draw a bit of power, maybe it’s overloading the hub? Do the lights come on in all the isolators?
hello thank you for your reply and interest in solving my problem.All ground isolators light up when I plug them into the hub. I use this one . atolla Powered USB 3.0 Hub 20W, 7… https://www.amazon.co.uk/dp/B07VGFXQRF?ref=ppx_pop_mob_ap_share and ectended usb USB Extension Cable 15M, USB2.0… https://www.amazon.co.uk/dp/B07TGV5WC3?ref=ppx_pop_mob_ap_share , thx
Likely the USB extension cable is the issue – signal integrity with multiple devices is likely too low. Why are you using USB and not CAN bus, which is designed for long wire lengths like that?
everything works fine if I don’t use
ground isolators ( I wanted to increase protection) but I can probably do without it. I use long cables because it has
a computer in the house and a platform in the garden house
I see. Well, you definitely need USB isolators to protect the ODrives. What OS are you using?
I use windows 10. Could you send me a link to the exact site of what I should buy?
I frankly think this is an issue caused by the USB extension cord and/or USB hub. I’d try a 2.0-only hub, or just switch to CAN bus if possible.
I will try first usb hub 2.0 . for a week I will give you
know when I try usb 2.0.thx I don’t know
nothing about cab-bus or how to turn it on and what it needs for that I am not
an expert in these things ![]()
