Hi everybody,
I’m trying to get my ODrive (V3.3) going for a pretty simple application: I want to use it in velocity mode to drive a spindle on my CNC mill. So essentially all I want to achieve is increase the max current, and set the mode to velocity mode to send it PWM signals.
Yet, somehow I have troubles connecting to it with the odrivetool to set it up. I used 2 different Win10 computers, both Python 3.7.
Firmware:
I had some pretty old firmware on it (from 2017), which did the initialization routine fine. Beep, spin in both direction, hold. Also, I can send position commands over git bash and echo to the Odrive. Yet, the odrivetool didn’t work with it.
So, according to the user guide for the V3.3 I took the ST-link and flashed the most up to date firmware onto the ODrive. Message post flash: " wrote 262144 bytes from file ODriveFirmware_v3.3.elf in 10.374247s (24.676 KiB/s) adapter speed: 2000 kHz". (From this I assume that OpenOCD is not the problem) One weird thing already here: there is no more beep and moving when it’s starting up. Motor also doesn’t have any holding power.
odrivetool
First of all I used Zadig to set the Driver to libusb-win32. Now, when I start up the tool in verbose mode, it is not connecting and giving me the following message: “no response - probably incompatible”.
I assume that something is going wrong during the flash.
Any suggestions what to try next?
Thanks for your help!
