odrivetool dfu did not find the controller so I put it in dfu mode swiching the dip switch. odrive dfu then gives this error:
odrivetool dfu
ODrive control utility v0.4.9
Waiting for ODrive…
Found ODrive 385B37563437 (v3.5-48V) with firmware [unknown version] in DFU mode
Checking online for newest firmware… found v0.4.10
Downloading firmware v0.4.10…
The configuration cannot be backed up because the device is already in DFU mode. The configuration may be lost after updating. Do you want to continue anyway? [Y/n] Y
Erasing… done
Flashing… (sector 1/6)
C:\ProgramData\Anaconda3\Scripts\odrivetool in
140 print_version()
141 import odrive.dfu
–> 142 odrive.dfu.launch_dfu(args, logger, app_shutdown_token)
143
144 elif args.command == ‘liveplotter’:
C:\ProgramData\Anaconda3\lib\site-packages\odrive\dfu.py in launch_dfu(args, logger, cancellation_token)
452 firmware = FirmwareFromFile(args.file) if args.file else None
453
–> 454 update_device(device, firmware, logger, cancellation_token)
455
456
C:\ProgramData\Anaconda3\lib\site-packages\odrive\dfu.py in update_device(device, firmware, logger, cancellation_token)
380 for i, (sector, data) in enumerate(touched_sectors):
381 print(“Flashing… (sector {}/{}) \r”.format(i, len(touched_sectors)), end=’’, flush=True)
–> 382 dfudev.write_sector(sector, data)
383 print(‘Flashing… done \r’, end=’’, flush=True)
384 finally:
C:\ProgramData\Anaconda3\lib\site-packages\odrive\dfuse\DfuDevice.py in write_sector(self, sector, data)
185 status = self.wait_while_state(DfuState.DFU_DOWNLOAD_BUSY)
186 if status[1] != DfuState.DFU_DOWNLOAD_IDLE:
–> 187 raise RuntimeError(“An error occured. Device Status: {!r}”.format(status))
188
189 def read_sector(self, sector):
