Hi, I accidentally ordered the wrong version of the Odrive3.6 but there is no contact info in the shop nor any cancellation procedure. Is there anything I can do to cancel it and order the more expensive one? I am in Europe, Netherlands.
supposedly the only difference between the 24V and 56V is the voltage rating on the capacitors. If you’re confident in your soldering skill it would not be impossible to swap them.
