When attempting to install the odrive using pip3 install I get this error:
The code always seems to freeze on:
Downloading https://files.pythonhosted.org/packages/be/74/24d058c17b155d131359f1cd01e120b3954686bf8b7853172b279237e1dc/matplotlib-3.1.3.tar.gz (40.9MB)
99% |████████████████████████████████| 40.9MB 26.0MB/s eta 0:00:01
and results in this error:
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-0gw9bigc/matplotlib/
I tried downloading monotonic, installing python-matplotlib seperately with no success… Any ideas?
tbt
April 6, 2020, 8:57pm
2
Hello, I got a Jetson Nano too and I’ve got almost the same error
I precise that I installed python &python3 & pip & pip3, tried with both and no success.
it result in this error :
Command “python setup.py egg_info” failed with error code 1 in /tmp/pip-build-o5ayL3/odrive/
Is someone could help us ?
Thx
tbt
April 6, 2020, 9:11pm
3
ok it needs monotonic and it works
tbt
April 6, 2020, 9:29pm
4
ok it works well with pip but trouble with pip3
I prefer py -2 -m pip install <pkg> or py -3 -m pip install <pkg> instead of the pip2 / pip3. Seems to be more reliable.
You can also directly call out the python version. C:/Tools/Python37/python.exe -m pip install odrive
Beluga
April 9, 2020, 10:13pm
6
Hi, I am having the same problem on a Jetson Nano. I already went through the same steps and installed monotonic and matplotlib manually. Still got the “python setup.py egg_info” failed with error code 1 in …
I think it has something to do with:
ERROR: Failed to build one or more wheels.
Also, when starting
sudo pip3 install odrive
When starting the procedure, it tells me the directories /home/beluga/.cache/pip/http and /home/beluga/.cache/pip is not owned by the current user. If executing pip with sudo, you may want sudo´s -H flag.
Please help me solve this problem.
Hello @Beluga ,
I had the same issue. Solved and it turns out that is because the system has an out of date version of setuptools.
just have a try and good luck
pip install --upgrade setuptools
Beluga
April 10, 2020, 8:55am
8
Wow, thank you very much for the quick answer. It helped installing odrivetools with pip (pip3 did not work). I hope everything will be working now, thank you again.
I use a Jetson Xavier NX and unfortunately have the same problem.
Unfortunately, none of the solutions work.
Hopefully someone else has a suggestion.
Solved it by installing mathplotlib manually
sudo apt-get install python-matplotlib
None of these helped for my trying to install on my Jetson Nano. I installed matplotlib, monotonic, setuptools.
What finally helped was suggestions in this thread: pip - Command “python setup.py egg_info” failed with error code 1 in /tmp/…/ - Stack Overflow .
Which is, I ran
pip3 install -U pip
pip3 install -U setuptools
And then ran pip3 install odrive. I hope this helps someone.
