I am using the micro Odrive board with a BLDC motor (High Current on GUI) and the onboard encoder. The motor has 4 pole pairs but it has a gear box and the magnet is placed at the end of the shaft. The board is throwing an error when I run calibration because it thinks the motor has a much larger number of pole pairs due to the gearbox, is there a way around this?
