Hi
I have a V3.4 board bought from a long time ago. Right now I am trying to reflash the board with the new firmware (3.4 -24V .elf) and following the steps from the doc on ODrive website. After I finished odrv0.axis0.requested_state = AXIS_STATE_FULL_CALIBRATION_SEQUENCE I start to run the line odrv0.axis0.requested_state = AXIS_STATE_CLOSED_LOOP_CONTROL and the motor becomes resistive, which is normal. Then I am using odrv0.axis0.controller.pos_setpoint = 10000, then what happened is the motor turns a little bit then stopped and lost the connection with the ODrive, which means that any more pos_setpoint commands will not make it move at all.
Can anyone help me on this?
BTW, the encoder_estimate for each motor is working so fine. The measured current is 0.5A.
I just checked the axis error it says 512. and the axis motor error is 16. Gonna keep digging it out.
