Greetings everyone,
So I have had some success with setting up my ODrive 3.8 with a hoverboard hub motor. Going through the ‘getting started’ section, I get all the way through odrv0.axis0.requested_state = AXIS_STATE_FULL_CALIBRATION_SEQUENCE, which executes just fine and the numbers look good, but once I attempt to run odrv0.axis0.controller.pos_setpoint = 10000, it does not work. I even tried 10, 100 and 1000 for a setpoint. To no avail. With that being said, I can get it to turn and stop through the
odrv0.axis0.controller.vel_setpoint command just fine.
I have already incorporated the capacitors for the hall sensors and even got a RC transmitter to properly send signals (confirmed via vel_setpoint) but cannot get the motor to turn through pos_setpoint. I ran the dump_errors(odrv0) with nothing to report on. Green across the board.
Any help would be appreciated! I’m sure I’m overlooking something
