hello,
I’m working on the big corexy chassis i posted a few weeks ago.
It’s rather massive compared to past projects I made. the gantry is likely a bit heavy (maybe overkill?).
Right now, when the gantry moves back and forth the chassis vibrates a lot because the big chassis it’s screwed an too small a table whereas the chassis should be bolted directly on the concrete floor (i plan to do that later)
The problem is due to those mecanic vibrations, the small plastic wheel to securely tight the CUI encoder wheel on the shaft tends to remove itself. And when that happens, the shaft rotates freely without turning the encoder. As a result, the odrive logic can no longer operate and the motors makes very fast erratic moves.
the gantry basically nearly crushed my head half an hour ago
I would rather avoid using Loctice super Glue to prevent it from moving.
I am pretty sure those encoders are just fine. Most likely scenario is that i do not clip it or mount it properly.
I took a picture to show the behavior. I had to modify brightness to show the symptoms. that blue plastic ring should be inside the encoder and it slips out.
Does someone has a tip to correctly mount it? maybe a youtube video? any advice?
I would rather not use definitive glue. but if it’s a matter of security, i dont have much choice. surely i msut be doing something wrong
