Hey,
I have run into a problem with the utils.py script. I wrote a few lines of code there to update a function but when I tried using it the function works the same as it did before I made my changes. I looked into it a bit further and when I look through the error the code gives it seems to use the old code even though I saved the file. I tried again with a different computer and the error persisted. The change I wrote looks like this:
def oscilloscope_dump(odrv, num_vals, filename='oscilloscope.csv'):
with open(filename, 'w') as f:
for x in range(num_vals):
f.write(str(odrv.oscilloscope.get_val(x,0)),str(odrv.oscilloscope.get_val(x,1)))
f.write('\n')
But in the error manager I get this: (the old code)
File ~/.local/lib/python3.8/site-packages/odrive/utils.py:258, in oscilloscope_dump(odrv, num_vals, filename)
256 with open(filename, 'w') as f:
257 for x in range(num_vals):
--> 258 f.write(str(odrv.oscilloscope.get_val(x)))
259 f.write('\n')
I don’t really know if this is just an issue on my end but any help would be appreciated.
