Hi all,
After updating the board firmware and odrivetool, the motor is not calibrating properly (no beeping sound) and the ODrive keeps reset (shown on the bottom). It used to work great before these updates. I am using the ‘SunnySky M8 135 KV motor’ with ‘CUI AMT102’ encoder purchased from ODrive.
First, I have downloaded the latest firmware .elf file at Release Firmware version 0.5.3 · odriverobotics/ODrive · GitHub, and then uploaded using STLink. When ‘odrivetool dfu’ command is used, the following error messages were seen and unable to detect when the odrivetool is ran:
ODrive control utility v0.5.3.post0
Waiting for ODrive...
Found ODrive 206437835753 (v3.6-56V) with firmware v0.5.3
Checking online for newest firmware... found v0.5.3
You are about to flash firmware v0.5.3 which is the same version as the firmware on the device (v0.5.3).
Downloading firmware v0.5.3...
Saving configuration to /var/folders/n5/dqmhqsf54xs882xwc0dtxzth0000gn/T/odrive-config-206437835753.json...
Configuration saved.
Putting device 206437835753 into DFU mode...
Erasing... done
Flashing... (sector 4/7)
File "/usr/local/bin/odrivetool", line 149, in <module>
File "/usr/local/lib/python3.9/site-packages/odrive/dfu.py", line 512, in launch_dfu
File "/usr/local/lib/python3.9/site-packages/odrive/dfu.py", line 434, in update_device
dfudev.write_sector(sector, data)
File "/usr/local/lib/python3.9/site-packages/odrive/dfuse/DfuDevice.py", line 219, in write_sector
raise make_exception(status)
Once the latest firmware is uploaded using STLink, the following parameters are set, and then, ran the calibration process.
Connected to ODrive 206437835753 as odrv0
Website: https://odriverobotics.com/
Docs: https://docs.odriverobotics.com/
Forums: https://discourse.odriverobotics.com/
Discord: https://discord.gg/k3ZZ3mS
Github: https://github.com/odriverobotics/ODrive/
Please connect your ODrive.
In [1]: odrv0.erase_configuration()
Oh no odrv0 disappeared
Reconnected to ODrive 206437835753 as odrv0
In [2]: odrv0.config.brake_resistance = 0.123
...: odrv0.axis0.motor.config.pole_pairs = 21
...: odrv0.axis0.motor.config.motor_type = MOTOR_TYPE_GIMBAL
...: odrv0.axis0.motor.config.calibration_current = 1.0
...: odrv0.axis0.motor.config.current_lim = 2 * odrv0.axis0.config.sensorless_ramp.current
...: odrv0.axis0.config.calibration_lockin.current = 1.0
...: odrv0.axis0.controller.config.input_filter_bandwidth = 1.0
...: odrv0.axis0.controller.config.control_mode = CONTROL_MODE_POSITION_CONTROL
...: odrv0.axis0.controller.config.pos_gain = 56
...: odrv0.axis0.controller.config.vel_gain = 0.02
...: odrv0.axis0.controller.config.vel_integrator_gain = 0.015
...: odrv0.axis1.motor.config.pole_pairs = 21
...: odrv0.axis1.motor.config.motor_type = MOTOR_TYPE_GIMBAL
...: odrv0.axis1.motor.config.calibration_current = 1.0
...: odrv0.axis1.motor.config.current_lim = 2 * odrv0.axis0.config.sensorless_ramp.current
...: odrv0.axis1.config.calibration_lockin.current = 1.0
...: odrv0.axis1.controller.config.input_filter_bandwidth = 1.0
...: odrv0.axis1.controller.config.control_mode = CONTROL_MODE_POSITION_CONTROL
...: odrv0.axis1.controller.config.pos_gain = 56
...: odrv0.axis1.controller.config.vel_gain = 0.02
...: odrv0.axis1.controller.config.vel_integrator_gain = 0.015
...: odrv0.axis0.controller.config.vel_limit = 1660
...: odrv0.axis0.config.sensorless_ramp.vel = 200
...: odrv0.axis0.config.sensorless_ramp.accel = 100
...: odrv0.axis0.config.sensorless_ramp.finish_distance = 50
...: odrv0.axis0.sensorless_estimator.config.pm_flux_linkage = 5.51328895422 / (21 * 135)
...: odrv0.axis1.controller.config.vel_limit = 1660
...: odrv0.axis1.config.sensorless_ramp.vel = 200
...: odrv0.axis1.config.sensorless_ramp.accel = 100
...: odrv0.axis1.config.sensorless_ramp.finish_distance = 50
...: odrv0.axis1.sensorless_estimator.config.pm_flux_linkage = 5.51328895422 / (21 * 135)
...: odrv0.config.enable_brake_resistor = True
...: odrv0.axis0.encoder.config.cpr = 8192
...: odrv0.axis0.encoder.config.mode = ENCODER_MODE_INCREMENTAL
...: odrv0.axis0.encoder.config.calib_range = 0.04
...: odrv0.axis1.encoder.config.cpr = 8192
...: odrv0.axis1.encoder.config.mode = ENCODER_MODE_INCREMENTAL
...: odrv0.axis1.encoder.config.calib_range = 0.04
In [3]: odrv0.save_configuration()
In [4]: odrv0.axis0.motor.config.pre_calibrated = False
...: odrv0.axis0.encoder.config.pre_calibrated = False
...: odrv0.axis0.encoder.config.use_index = True
...: odrv0.axis0.requested_state = AXIS_STATE_FULL_CALIBRATION_SEQUENCE
In [5]: odrv0.axis0.motor.config.pre_calibrated = True
...: odrv0.axis0.encoder.config.pre_calibrated = True
In [6]: odrv0.save_configuration()
In [7]: odrv0.axis0.requested_state = AXIS_STATE_ENCODER_INDEX_SEARCH
In [8]: odrv0.axis0.requested_state = AXIS_STATE_ENCODER_INDEX_SEARCH
In [9]: odrv0.axis0.requested_state = AXIS_STATE_ENCODER_INDEX_SEARCH
In [10]: odrv0.axis0.controller.config.input_mode = INPUT_MODE_POS_FILTER
...: odrv0.axis0.requested_state = AXIS_STATE_CLOSED_LOOP_CONTROL
...: odrv0.axis0.controller.input_pos = 0
Here are two problems:
- When it was working properly, it found the index signal first (beep), and then rotate back and forth to complete the calibration process. However, with the updated firmware, it just rotates back and forth to complete (no beep), and then, unable to find the position when AXIS_STATE_ENCODER_INDEX_SEARCH is called
- This could be happening due to the calibration problem, but when the torque is enabled, the ODrive board gets disconnected and connected back and forth
It would be appreciated if anyone could share the simple solution to fix this problem. The motor was working just fine for the last 6 months, but suddenly, everything is not working at this point.
