hello everyone,
I don’t know what is the problem with the motor. sometimes I have to move the motor vertical so can rotates but not always. Any ideas why? cable conexion ?
- Motor ODrive D5065 270KV
- ODrive Motor controller board V3.6
- ODrive power resistor 50W
- Encoder CUI AMT 102-V 4420
#restore the motherboard default parameters
odrv0.erase_configuration()
#1 config dissipation resistor
#2 config low voltage portection threshold
odrv0.config.dc_bus_undervoltage_trip_level= 8.0
#3 config overvoltage protection threshold
odrv0.config.dc_bus_overvoltage_trip_level= 56.0
#4 config overcurrent protection threshold
odrv0.config.dc_max_positive_current = 20.0
#5 config the reverse overcurrent protection threshold
odrv0.config.dc_max_negative_current =-1.0
#6 config the recharge current value
odrv0.config.max_regen_current =0
#7 save config parameters
odrv0.save_configuration()
#Part2: motor parameter configuration
#1 config the number of motor pole pairs
odrv0.axis0.motor.config.pole_pairs=7
#2 config the current when the motor is calibrated
odrv0.axis0.motor.config.calibration_current =5
#3 config the voltage when the motor is calibrated
odrv0.axis0.motor.config.resistance_calib_max_voltage= 2
#4 config motor type
odrv0.axis0.motor.config.motor_type=MOTOR_TYPE_HIGH_CURRENT
#5 Config the maximum current limit for motor operation
odrv0.axis0.motor.config.current_lim = 10 # [A]
#6 config the motor current sampling range
odrv0.axis0.motor.config.requested_current_range = 20
odrv0.axis0.motor.config.current_control_bandwidth = 2000
odrv0.axis0.motor.config.torque_constant = 8.27 / 270
odrv0.axis0.motor.config.torque_lim= 1.3
# part 3
#encoder parameter config
#1 config encoder type
odrv0.axis0.encoder.config.mode= ENCODER_MODE_INCREMENTAL
#2 Config encoder resolution
odrv0.axis0.encoder.config.cpr =8192
odrv0.axis0.encoder.config.enable_phase_interpolation = True
#3 config encoding bandwith
odrv0.axis0.encoder.config.bandwidth=3000
#4 motor running current when configuring encoder calibration
odrv0.axis0.config.calibration_lockin.current =3
#5 config the current rise time during encoder calibration
odrv0.axis0.config.calibration_lockin.ramp_time = 0.4
#6 config the motor rotation distance when the current rises
odrv0.axis0.config.calibration_lockin.ramp_distance = 3.1415927410125732
#7 motor acceletation when configuring encoder calibration
odrv0.axis0.config.calibration_lockin.accel=20
#8 motor speed when configuring encoder calibration
odrv0.axis0.config.calibration_lockin.vel=40
#9 save config parameters
#PART 4
#1 config control mode
odrv0.axis0.controller.config.control_mode= CONTROL_MODE_POSITION_CONTROL
#2 config the maximum speed of the motor
odrv0.axis0.controller.config.vel_limit=5
#3 config position loop gain
odrv0.axis0.controller.config.pos_gain =30
#4 config speed loop gain
odrv0.axis0.controller.config.vel_gain = 0.2
odrv0.axis0.controller.config.vel_integrator_gain = 0.5 * 10 * 0.2
#5 config input mode
odrv0.axis0.controller.config.input_mode= INPUT_MODE_TRAP_TRAJ
#6 Config the motor speed in trapezoidal mode
odrv0.axis0.trap_traj.config.vel_limit =30
#7 config the motor acceleration/deceleration in trapezoidal
odrv0.axis0.trap_traj.config.accel_limit =5
odrv0.axis0.trap_traj.config.decel_limit =5
#8 save the config
odrv0.reboot()
#CALIBRATION
#odrv0.reboot()
#odrv0.clear_errors()
#dump_errors(odrv0)
#odrv0.axis0.controller.config.input_mode = AXIS_STATE_CLOSED_LOOP_CONTROL
odrv0.axis0.requested_state =AXIS_STATE_CLOSED_LOOP_CONTROL
odrv0.axis0.controller.input_pos =50
odrv0.axis0.controller.input_pos =0
This is the error i get
system: no error
axis: no error
motor: Error(s):
MOTOR_ERROR_UNKNOWN_TORQUE
MOTOR_ERROR_UNKNOWN_VOLTAGE_COMMAND
encoder: Error(s):
ENCODER_ERROR_CPR_POLEPAIRS_MISMATCH
controller: Error(s):
CONTROLLER_ERROR_OVERSPEED
axis1
axis: no error
motor: no error
