Hello. I use a 3.5-48v board and AS5047 Encoders.
Must use absolute angle through SPI.
I clone https://github.com/TobinHall/ODrive/tree/Non-Blocking_Absolute_SPI repository and compile in Visual Studio Code successfully!!!.
But when trying to flash sudo dfu-util -a 0 -s 0x08000000 -D build/ODriveFirmware.bin.
Errors pop up;
dfu-util 0.9
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2016 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
dfu-util: Invalid DFU suffix signature
dfu-util: A valid DFU suffix will be required in a future dfu-util release!!!
Opening DFU capable USB device...
ID 0483:df11
Run-time device DFU version 011a
Claiming USB DFU Interface...
Setting Alternate Setting #0 ...
Determining device status: state = dfuERROR, status = 10
dfuERROR, clearing status
Determining device status: state = dfuIDLE, status = 0
dfuIDLE, continuing
DFU mode device DFU version 011a
Device returned transfer size 2048
DfuSe interface name: "Internal Flash "
Downloading to address = 0x08000000, size = 134283264
dfu-util: Last page at 0x1000ffff is not writeable
I use Linux Ubuntu 18.04. The official documentation on the site https://docs.odriverobotics.com/odrivetool says:
Force DFU mode, as per the instructions above. In the Firmware directory, after finishing building the firmware: sudo dfu-util -a 0 -s 0x08000000 -D build/ODriveFirmware.bin
If you write like this: sudo dfu-util -a 0 -s 0x08000000 -D build/ODriveFirmware.hex
The firmware is successfully installed but the program odrivetool does not see the connected board.
For official firmware sudo dfu-util -a 0 -s 0x08000000 -D build/ODriveFirmware.hex also does not see the board odrivetool program.
~/ODriveSPI/ODrive/Firmware$ sudo odrivetool dfu build/ODriveFirmware.hex
[sudo] password for innopolis:
ODrive control utility v0.4.11
Waiting for ODrive...
Found ODrive 206537793548 (v3.5-48V) with firmware [unknown version]
You are about to flash firmware [unknown version] which is the same version as the firmware on the device ([unknown version]).
Saving configuration to /tmp/odrive-config-206537793548.json...
Configuration saved.
Putting device 206537793548 into DFU mode...
Erasing... done
Flashing... done
Verifying... done
Waiting for the device to reappear...
Restoring configuration from /tmp/odrive-config-206537793548.json...
Could not restore axis0.config.watchdog_timeout: property not found on device
Could not restore axis0.config.step_gpio_pin: property not found on device
Could not restore axis0.config.dir_gpio_pin: property not found on device
Could not restore axis0.motor.config.current_lim_tolerance: property not found on device
Could not restore axis0.motor.config.inverter_temp_limit_lower: property not found on device
Could not restore axis0.motor.config.inverter_temp_limit_upper: property not found on device
Could not restore axis0.controller.config.vel_limit_tolerance: property not found on device
Could not restore axis0.controller.config.vel_ramp_rate: property not found on device
Could not restore axis0.controller.config.setpoints_in_cpr: property not found on device
Could not restore axis0.encoder.config.find_idx_on_lockin_only: property not found on device
Could not restore axis0.encoder.config.zero_count_on_find_idx: property not found on device
Could not restore axis0.encoder.config.enable_phase_interpolation: property not found on device
Could not restore axis0.encoder.config.calib_scan_distance: property not found on device
Could not restore axis0.encoder.config.calib_scan_omega: property not found on device
Could not restore axis0.encoder.config.idx_search_unidirectional: property not found on device
Could not restore axis0.encoder.config.ignore_illegal_hall_state: property not found on device
Could not restore axis1.config.watchdog_timeout: property not found on device
Could not restore axis1.config.step_gpio_pin: property not found on device
Could not restore axis1.config.dir_gpio_pin: property not found on device
Could not restore axis1.motor.config.current_lim_tolerance: property not found on device
Could not restore axis1.motor.config.inverter_temp_limit_upper: property not found on device
Could not restore axis1.controller.config.vel_limit_tolerance: property not found on device
Could not restore axis1.controller.config.vel_ramp_rate: property not found on device
Could not restore axis1.controller.config.setpoints_in_cpr: property not found on device
Could not restore axis1.encoder.config.find_idx_on_lockin_only: property not found on device
Could not restore axis1.encoder.config.zero_count_on_find_idx: property not found on device
Could not restore axis1.encoder.config.enable_phase_interpolation: property not found on device
Could not restore axis1.encoder.config.calib_scan_distance: property not found on device
Could not restore axis1.encoder.config.calib_scan_omega: property not found on device
Could not restore axis1.encoder.config.idx_search_unidirectional: property not found on device
Could not restore axis1.encoder.config.ignore_illegal_hall_state: property not found on device
Some of the configuration could not be restored.
Configuration restored.
Device firmware update successful.
In the firmware you are uploading this option no longer exists. Odrivetool is trying to restore all the values, but let’s you know which values it could not find anymore. Don’t worry about these notifications.
Judging by the values you are listing, the firmware you are uploading is quite a bit older than the one you had installed. It might be worth looking at the branch razorsedge by @Wetmelon. I’m not sure if it has the feature you are trying to add, but it probably does.
same issue here. however, I use sudo odrivetool dfu build/ODriveFirmware.hex,still failed… so sad
Waiting for ODrive…
Found ODrive 20823599524B (v3.6-24V) with firmware [unknown version] in DFU mode
Checking online for newest firmware… found v0.4.11
Downloading firmware v0.4.11…
The configuration cannot be backed up because the device is already in DFU mode. The configuration may be lost after updating. Do you want to continue anyway? [Y/n] y
Erasing… done
Flashing… done
Verifying… done
Waiting for the device to reappear…
File “/usr/local/bin/odrivetool”, line 142, in
File “/usr/local/lib/python3.6/dist-packages/odrive/dfu.py”, line 454, in launch_dfu
File “/usr/local/lib/python3.6/dist-packages/odrive/dfu.py”, line 415, in update_device
cancellation_token, cancellation_token, timeout=300)
File “/usr/local/lib/python3.6/dist-packages/fibre/discovery.py”, line 126, in find_any
done_signal.wait(timeout=timeout)
File “/usr/local/lib/python3.6/dist-packages/fibre/utils.py”, line 91, in wait
raise TimeoutError()
TimeoutError
