I tried to calibrate M0 and M1 and got this error:
config:
abs_spi_cs_gpio_pin: 1 (uint16)
bandwidth: 250.0 (float)
calib_scan_distance: 150.0 (float)
cpr: 90 (int32)
direction: 1 (int32)
find_idx_on_lockin_only: False (bool)
hall_polarity: 0 (uint8)
hall_polarity_calibrated: False (bool)
index_offset: 0.0 (float)
mode: 1 (uint16)
phase_offset: 0 (int32)
phase_offset_float: 0.0 (float)
pre_calibrated: False (bool)
use_index: False (bool)
use_index_offset: True (bool)
count_in_cpr: 0 (int32)
delta_pos_cpr_counts: 0.0 (float)
error: 528 (uint16)
hall_state: 1 (uint8)
index_found: False (bool)
interpolation: 0.5 (float)
is_ready: False (bool)
phase: 0.0 (float)
pos_abs: 0 (int32)
pos_circular: 0.0 (float)
pos_estimate: 0.0 (float)
pos_estimate_counts: 0.0 (float)
shadow_count: 0 (int32)
spi_error_rate: 0.0 (float)
vel_estimate: 0.0 (float)
vel_estimate_counts: 0.0 (float) and Axis1:
calib_scan_response: 144.0 (float)
config:
cpr: 90 (int32)
hall_polarity_calibrated: True (bool)
mode: 1 (uint16)
phase_offset: 69 (int32)
phase_offset_float: 1.4637079238891602 (float)
count_in_cpr: 88 (int32)
delta_pos_cpr_counts: 5.605193857299268e-45 (float)
error: 0 (uint16)
hall_state: 4 (uint8)
is_ready: True (bool)
phase: 0.03800535202026367 (float)
pos_abs: 0 (int32)
pos_circular: 0.9784607291221619 (float)
pos_cpr_counts: 88.0615234375 (float)
pos_estimate: -0.02153862826526165 (float)
pos_estimate_counts: -1.9384765625 (float)
shadow_count: -2 (int32)
I tried the solution of adding capacitors 22uf but still getting the error. What is weird is that I always get count_in_cpr: 0 on M0, even if I swap the motors M1 works ok but M0 fails during calibration.
Any suggestion of what can be the problem?
