Looking at the encoder calibration implementation, I discovered it uses an open-loop controller:
          axis_->open_loop_controller_.Idq_setpoint_ = {0.0f, 0.0f};
          axis_->open_loop_controller_.Vdq_setpoint_ = {0.0f, 0.0f};
          axis_->open_loop_controller_.phase_ = 0.0f;
          axis_->open_loop_controller_.phase_vel_ = 0.0f;
float max_current_ramp = axis_->motor_.config_.calibration_current / start_lock_duration * 2.0f;
          axis_->open_loop_controller_.max_current_ramp_ = max_current_ramp;
          axis_->open_loop_controller_.max_voltage_ramp_ = max_current_ramp;
          axis_->open_loop_controller_.max_phase_vel_ramp_ = INFINITY;
          axis_->open_loop_controller_.target_current_ = axis_->motor_.config_.motor_type != Motor::MOTOR_TYPE_GIMBAL ? axis_->motor_.config_.calibration_current : 0.0f;
          axis_->open_loop_controller_.target_voltage_ = axis_->motor_.config_.motor_type != Motor::MOTOR_TYPE_GIMBAL ? 0.0f : axis_->motor_.config_.calibration_current;
          axis_->open_loop_controller_.target_vel_ = 0.0f;
          axis_->open_loop_controller_.total_distance_ = 0.0f;
          axis_->open_loop_controller_.phase_ = axis_->open_loop_controller_.initial_phase_ = wrap_pm_pi(0 - config_.calib_scan_distance / 2.0f);
However, I wasn’t able to find a Python API for it. Is there any way I can explicitly utilize the open-loop controller (e.g. set a specific speed) from the Python library?
