the code which perform motor phase resistance calibrate like
actual_current_ = Ialpha_beta->first;
test_voltage_ += (kI * current_meas_period) * (target_current_ - actual_current_);
I_beta_ += (kIBetaFilt * current_meas_period) * (Ialpha_beta->second - I_beta_);
float vfactor = 1.0f / ((2.0f / 3.0f) * *vbus_voltage);
test_mod_ = test_voltage_ * vfactor;
*mod_alpha_beta = {*test_mod_, 0.0f};
*ibus = *test_mod_ * actual_current_;
float get_resistance() {
return test_voltage_ / target_current_;
is there any reference to descripe how resistance and inductive calibration?
what test_mod_ mean ? why need to mul vbus_voltage?
The resistance measurement is a simple PI controller that outputs a set current, then measures the duty cycle required * the bus voltage:
V = IR
V_{bus} * DC \% = I R
The inductance measurement applies a 4kHz square wave and measures the rise/fall time.
okk . I understand since i see the mainitude of the alpha-beta vector may not large than sqrt(3)/2 . It stand for the percentage of Vbus.
but for inductance measure , how can I know the 4kHz square wave from the following code?
struct InductanceMeasurementControlLaw : AlphaBetaFrameController {
void reset() final {
attached_ = false;
ODriveIntf::MotorIntf::Error on_measurement(
std::optional<float> vbus_voltage,
std::optional<float2D> Ialpha_beta,
uint32_t input_timestamp) final
if (!Ialpha_beta.has_value()) {
return {Motor::ERROR_UNKNOWN_CURRENT_MEASUREMENT};
float Ialpha = Ialpha_beta->first;
if (attached_) {
float sign = test_voltage_ >= 0.0f ? 1.0f : -1.0f;
deltaI_ += -sign * (Ialpha - last_Ialpha_);
} else {
start_timestamp_ = input_timestamp;
attached_ = true;
last_Ialpha_ = Ialpha;
last_input_timestamp_ = input_timestamp;
return Motor::ERROR_NONE;
ODriveIntf::MotorIntf::Error get_alpha_beta_output(
uint32_t output_timestamp, std::optional<float2D>* mod_alpha_beta,
std::optional<float>* ibus) final
test_voltage_ *= -1.0f;
float vfactor = 1.0f / ((2.0f / 3.0f) * vbus_voltage);
*mod_alpha_beta = {test_voltage_ * vfactor, 0.0f};
*ibus = 0.0f;
