Relevant source files and STM32 pins for debugging
I am working with an Odrive that hasn’t worked out of the box. The latest update on the problem can be seen here .
Luckily the Odrive firmware is open source and I can debug the controller and see why it is not working.
I am not sure if this is in the documentation so I would kindly like to ask where can I get the following information:
  • Which source files can I check for when the Firmware is controlling the Motor (in sensorless and sensor mode)? Particularly, I am interested in checking when the DRV8301 chip is being used for the main control.
  • Is there any information about the software architecture to comprehend the firmware? For example UML, C4, Sysml,etc. This would give me a good idea of the software implementation and debug the issue.
  • Which pins from the STM32 can I check for debugging the DRV8301 gate driver IC and the Hall Sensor inputs with a logic analyzer?
Thanks in advanced
Any time the motors are “armed” (see axis.cpp)
No, sorry.
If your board isn’t working, you should contact info@odriverobotics.com for help.
