Hi, I want to make some changes to the v0.5.1 ODrive firmeware. I followed the instructions in the ODrive documentation and installed all of the prerequisites for win10 VSCode. Sadly, I failed in the step “Run Build Task”. However, the strange thing is that, when I switched the ODrive source code to verison v0.4.12, I succeed in build the code and no errors were reported. So I want to know if there is something specifical I should do to build the v0.5.1 ODrive firmeware?
The terminal’s error report in buildiing v0.5.1 ODrive is as followes:
> Executing task in folder Firmware: make <
- [ ] 0%tup error: failed to create child process: No such file or directory*
- *** Command ID=633 failed: g++ -O3 -std=c++17 -I. -I./MotorControl -I./fibre/cpp/include -I./Drivers/DRV8301 -I./doctest -c Tests/test_timer.cpp -o Tests/bin/test_timer.o*
- *** Command ID=629 failed: g++ -O3 -std=c++17 -I. -I./MotorControl -I./fibre/cpp/include -I./Drivers/DRV8301 -I./doctest -c Tests/test_rotate.cpp -o Tests/bin/test_rotate.o*
- *** Command ID=631 failed: g++ -O3 -std=c++17 -I. -I./MotorControl -I./fibre/cpp/include -I./Drivers/DRV8301 -I./doctest -c Tests/test_runner.cpp -o Tests/bin/test_runner.o*
- *** Command ID=627 failed: g++ -O3 -std=c++17 -I. -I./MotorControl -I./fibre/cpp/include -I./Drivers/DRV8301 -I./doctest -c Tests/test_can.cpp -o Tests/bin/test_can.o*
- [ ] 0%*
- *** tup: 4 jobs failed.*
make: *** [Makefile:14: all] Error 1
The terminal process terminated with exit code: 1
