Hi together,
i have set up the odrive board in gimbal mode as described in the getting started. Startup procedure should fine. After type in odrv0.axis0.requested_state = AXIS_STATE_CLOSED_LOOP_CONTROL the motor should try to hold the motor’s position but I can simply turn it. Velocity control does not work either. Any ideas?
Motor is a EMAX GB4008 with an ams AS5147P encoder (A, B, no index).
Code:
odrv0.config.brake_resistance = 2 odrv0.axis1.motor.config.pole_pairs = 11 odrv0.axis1.motor.config.current_lim = 8.4 odrv0.axis1.controller.config.vel_limit = 3 odrv0.axis1.motor.config.calibration_current = 3 odrv0.axis1.motor.config.motor_type = MOTOR_TYPE_GIMBAL odrv0.axis1.encoder.config.cpr = 4096 odrv0.axis1.motor.config.direction = 1 odrv0.save_configuration() odrv0.reboot() odrv0.axis1.requested_state = AXIS_STATE_FULL_CALIBRATION_SEQUENCE
Thanks
Jannis
