I am not sure what these messages (regarding import sys) and the rest mean but this is not an error. Odrivetool still works.
odrivetool -v
ODrive control utility v0.4.11
Waiting for ODrive…
USB discover loop
ConfigurationValue 1
InterfaceNumber 0,0
EndpointAddress 130
InterfaceNumber 1,0
EndpointAddress 1
EndpointAddress 129
InterfaceNumber 2,0
EndpointAddress 3
EndpointAddress 131
Kernel Driver was not attached
EndpointAddress for writing 3
EndpointAddress for reading 131
Connecting to device on USB device bus 2 device 12
/usr/local/lib/python3.7/dist-packages/fibre/shell.py:104: RuntimeWarning: coroutine ‘InteractiveShell.run_code’ was never awaited
console.runcode(‘import sys’)
RuntimeWarning: Enable tracemalloc to get the object allocation traceback
/usr/local/lib/python3.7/dist-packages/fibre/shell.py:105: RuntimeWarning: coroutine ‘InteractiveShell.run_code’ was never awaited
console.runcode(‘superexcepthook = sys.excepthook’)
/usr/local/lib/python3.7/dist-packages/fibre/shell.py:106: RuntimeWarning: coroutine ‘InteractiveShell.run_code’ was never awaited
console.runcode(‘def newexcepthook(ex_class,ex,trace):\n’
/usr/local/lib/python3.7/dist-packages/fibre/shell.py:109: RuntimeWarning: coroutine ‘InteractiveShell.run_code’ was never awaited
console.runcode(‘sys.excepthook=newexcepthook’)
Please connect your ODrive.
I also had problems getting odrivetool and Win 10 to play nice with the Odrive. My cure was to switch to Ubuntu. Worked inside a VMWare instance, so, it wasn’t USB hardware related.
0.4.12 on a 56V V3.6 board running at 24V on a bench supply or 48V on a battery.
Thanks for posting this, it helped me with a similar problem.
I’m also still seeing these warnings. Everything seems to work fine, it’s just annoying.
pi@raspberrydrive:~ $ sudo odrivetool -v
ODrive control utility v0.4.12
Waiting for ODrive...
USB discover loop
InterfaceNumber 0,0
EndpointAddress 130
InterfaceNumber 1,0
EndpointAddress 1
EndpointAddress 129
InterfaceNumber 2,0
EndpointAddress 3
EndpointAddress 131
Connecting to device on USB device bus 1 device 10
/usr/local/lib/python3.7/dist-packages/fibre/shell.py:104: RuntimeWarning: coroutine 'InteractiveShell.run_code' was never awaited
console.runcode('import sys')
/usr/local/lib/python3.7/dist-packages/fibre/shell.py:105: RuntimeWarning: coroutine 'InteractiveShell.run_code' was never awaited
console.runcode('superexcepthook = sys.excepthook')
/usr/local/lib/python3.7/dist-packages/fibre/shell.py:106: RuntimeWarning: coroutine 'InteractiveShell.run_code' was never awaited
console.runcode('def newexcepthook(ex_class,ex,trace):\n'
/usr/local/lib/python3.7/dist-packages/fibre/shell.py:109: RuntimeWarning: coroutine 'InteractiveShell.run_code' was never awaited
console.runcode('sys.excepthook=newexcepthook')
In [1]:
JSON: [
I too have the error, I just upgraded my OS from Ubuntu 18.04 to 20.04, the drive works fine but still the error is annoying.
