I need your valuable help ![]()
The motor speed is limited in the configuration up to 100rpm/s but in the graph you can see the speed limit is 55turns/s. Why?
Hi RaulG,
Likely this is due to inadequate supply voltage - that graph looks exactly like motor saturation. What motor and supply voltage are you using? Note that the ODrive v3.6 is limited to a 70% modulation magnitude due to hardware constraints - so the maximum speed will be 0.7 * supply_voltage * motor_kv.
Yeah! You are right!
Voltage = 24V
kv = 162rpm/V
According your comments … MaxSpeed = 24V * 182 rpm/ V * 1/60 * 0.7 = 51rev/s
Where I can read this kind of limitations? i didn’t see in the manual…
Unfortunately this isn’t very well documented, apologies - v3.6 is end of life, and its documentation is no longer being updated. Strangely, this is actually a very common limitation among BLDC controllers, just not very frequently mentioned.
