I’m having an issue where the motor on one axis starts spinning uncontrollably after enabling closed loop control. The steps I take in odrivetool right after bootup are as follows:
In [1]: odrv0.axis0.requested_state=AXIS_STATE_ENCODER_INDEX_SEARCH
In [2]: odrv0.axis0.requested_state=AXIS_STATE_CLOSED_LOOP_CONTROL
starts spinning
I got a printout of axis0, and interestingly pos_setpoint seems to take a very large (absolute) value (-1.0744717534594085e+24):
In [5]: odrv0.axis0
Out[5]:
controller:
current_setpoint = -0.0 (float)
vel_setpoint = -2.943871909072946e+21 (float)
vel_ramp_enable = False (bool)
error = 0x0000 (int)
set_pos_setpoint(pos_setpoint: float, vel_feed_forward: float, current_feed_forward: float)
vel_integrator_current = 0.0 (float)
vel_ramp_target = 0.0 (float)
pos_setpoint = -1.0744717534594085e+24 (float)
config: ...
move_to_pos(goal_point: float)
requested_state = 0 (int)
motor:
timing_log: ...
current_meas_phC = -0.036374807357788086 (float)
gate_driver: ...
config: ...
phase_current_rev_gain = 0.05000000074505806 (float)
DC_calib_phB = -2.629551649093628 (float)
is_calibrated = True (bool)
armed_state = 0 (int)
current_meas_phB = -0.19068455696105957 (float)
DC_calib_phC = -2.703293561935425 (float)
current_control: ...
encoder:
is_ready = True (bool)
vel_estimate = 0.0 (float)
count_in_cpr = 3234 (int)
pos_estimate = -54109.76953125 (float)
pos_cpr = 3234.234375 (float)
config: ...
shadow_count = -54110 (int)
interpolation = 0.5 (float)
phase = -1.6917487382888794 (float)
hall_state = 3 (int)
index_found = True (bool)
config:
counts_per_step = 2.0 (float)
spin_up_current = 10.0 (float)
ramp_up_distance = 12.566370964050293 (float)
ramp_up_time = 0.4000000059604645 (float)
step_gpio_pin = 1 (int)
spin_up_acceleration = 400.0 (float)
dir_gpio_pin = 2 (int)
spin_up_target_vel = 400.0 (float)
current_state = 1 (int)
get_temp()
step_dir_active = False (bool)
trap_traj:
config: ...
sensorless_estimator:
pll_pos = 2.9749515056610107 (float)
config: ...
vel_estimate = -0.20460842549800873 (float)
phase = 2.9748737812042236 (float)
loop_counter = 2993403 (int)
resetting this value manually seems to have no effect and on a next printout it still remains unusually large.
I’m on 0.4.7. This occurred once in the past and I ignored it, but now it seems to become a repeating pattern.
Any help/ideas would be greatly appreciated.
