Hi, I use python 3.10,
my odrive firmware is
I can use the command start_live plotter, but there is no plot on screen.
could you provide some solution?
thanks !
thanks !
start_liveplotter is a function, so you need to call it with the required arguments.
You can see from the output that there is a required argument get_var_callback, and an optional argument legend
get_var_callback will look something like lambda: [odrv0.vbus_voltage, odrv0.ibus] (replace vbus_voltage and ibus with the properties you want to plot)
If you want to define the legend for this, you would use: legend = ["Bus Voltage", "Bus Current"]
So, all together you should be entering
start_liveplotter(lambda: [odrv0.vbus_voltage, odrv0.ibus], legend = ['Bus Voltage", "Bus Current"])
thanks!
