We have the odrive running, but all of the sudden it started to behave weirdly. it was running on a backeup config file which didnt require calibration on startup, but now it wont move unless we calibrate it. Even after a succesfull restore of the config file, it wont change.
When I dump the errors I get the following:
When we run our python code we get the following error:
pi@raspberrypi:~ $ rosrun odrive_ros odrive_basic_node.py
ConfigurationValue 1
InterfaceNumber 0,0
EndpointAddress 130
InterfaceNumber 1,0
EndpointAddress 1
EndpointAddress 129
InterfaceNumber 2,0
EndpointAddress 3
EndpointAddress 131
Kernel Driver was not attached
EndpointAddress for writing 3
EndpointAddress for reading 131
Connecting to device on USB device bus 1 device 19
Device reported JSON version ID: 2604684226
JSON: [
{'name': '', 'id': 0, 'type': 'json', 'access': 'r'},
{'name': 'vbus_voltage', 'id': 1, 'type': 'float', 'access': 'r'},
{'name': 'ibus', 'id': 2, 'type': 'float', 'access': 'r'},
{'name': 'ibus_report_filter_k', 'id': 3, 'type': 'float', 'access': 'rw'}, ...
*ETC.. see entire pastebin for errors*
malformed member : unsupported codec json
Connected to ODrive. ODrive 35619129216333, hw v3.6-56, fw v0.5.1-dev, sdk v0.5.1
Already connected. Disconnecting and reconnecting.
InterfaceNumber 0,0
EndpointAddress 130
InterfaceNumber 1,0
EndpointAddress 1
EndpointAddress 129
InterfaceNumber 2,0
EndpointAddress 3
EndpointAddress 131
receiver thread is exiting: Traceback (most recent call last):
File "/usr/local/lib/python3.7/dist-packages/fibre/usbbulk_transport.py", line 127, in get_packet
ret = self.epr.read(bufferLen, timeout)
File "/home/pi/.local/lib/python3.7/site-packages/usb/core.py", line 421, in read
return self.device.read(self, size_or_buffer, timeout)
File "/home/pi/.local/lib/python3.7/site-packages/usb/core.py", line 1022, in read
self.__get_timeout(timeout))
File "/home/pi/.local/lib/python3.7/site-packages/usb/backend/libusb1.py", line 851, in bulk_read
timeout)
File "/home/pi/.local/lib/python3.7/site-packages/usb/backend/libusb1.py", line 954, in __read
_check(retval)
File "/home/pi/.local/lib/python3.7/site-packages/usb/backend/libusb1.py", line 604, in _check
raise USBError(_strerror(ret), ret, _libusb_errno[ret])
usb.core.USBError: [Errno 19] No such device (it may have been disconnected)
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.7/dist-packages/fibre/protocol.py", line 241, in receiver_thread
response = self._input.get_packet(deadline)
File "/usr/local/lib/python3.7/dist-packages/fibre/usbbulk_transport.py", line 134, in get_packet
raise fibre.protocol.ChannelBrokenException()
JSON: [
{'name': 'serial_number', 'id': 4, 'type': 'uint64', 'access': 'r'},
**ETC..**
{'name': 'erase_configuration', 'id': 545, 'type': 'function', 'inputs': [], 'outputs': []},
{'name': 'reboot', 'id': 546, 'type': 'function', 'inputs': [], 'outputs': []},
{'name': 'enter_dfu_mode', 'id': 547, 'type': 'function', 'inputs': [], 'outputs': []}]
<class 'int'>
<class 'int'>
The entire error can be seen here: https://pastebin.com/4fH4hLzJ
I hope you can help
