I would like to generate a local, on premises, version of the current documentation for the ODrives.
The previous version is available on GitHub but not adequate for the current/new generation.
I understand that the development is no longer open but the RST files for the documentation would be useful for such endeavor as mine.
What do you think ? Is it possible ?
              Hi! Let me check in and get back to you on this.
              @pfelecan We’re working on a better solution for offline docs, for now here’s a dump of the HTML for 0.6.10: odrive_docs_v0_6_10.zip - Google Drive
              Thank you so much for the archive; installed and works like a charm.
Please let me know when there is a solution to generate the documentation from the sources; maybe a separate github repository just for that ?
              Will do! We’re planning on putting something together to release the all-in-one docs automatically, would that work for your needs?
              Yes, would work. Thank you for your effort.
