The M0 in both my 2 boards work well, but the M1 in both can’t work at all,
odrv0.axis1.error = 65
odrv0.axis1.motor.error = 8
odrv0.axis1.motor.gate_driver.drv_fault = 0
Do you know what is the problem?
i have the exact same thing with m1 not working on two boards with m0 working fine on both :\ same motors/wiring/configuration.
edit: ignore this thread hijack totally different
Which hardware version of the board do you have? Did you make your own board or did you buy it from ODrive Robotics?
They are the V3.3 boards I made.
Motor error 8 is DRV_FAULT, which indicates an issue with the hardware. We fixed all the DRV_FAULT issues in ODrive v3.5 (at least no reports so far).
Oh, is it possible to make the M1 in v3.3 board work by some modification?
Try this fix:
Thank you very much, I will try.
