On my pick and place machine I have a stepper driving an GT2 pulley on one end of the axis, and the pulley on the other end is on the same shaft as the encoder. This has some advantages: the encoder can detect a slipping or broken belt and it’s a bit easier mechanically.
However, I’m a bit conserned about this setup if I replace the steppers with brusless motors and an odrive board because I read somewhere on this site that the encoder should be tightly coupled to the motor. Will this setup work with an odrive, or would I need to mount the encoders directly on the motor shafts?
